September 15, 2023 at 2:56 pm
Muhammad Aditya Nugraha
SubscriberI have varied contact condition in Brake Pad Simulation. I got conclusion that higher friction coefficient (range between 0,1 to 0,4) means higher equivalent stress too (please told me if i'm wrong about this conclusion).
But, if i compared equivalent stress at frictionless with 0,1 friction coefficient, i got "anomaly". The equivalent stress at frictionless is higher than 0,1 friction coefficient one. Is it true about this "anomaly" or is there something wrong in my simulation process?. If it's true, why and how does this "anomaly" happen? -
September 16, 2023 at 9:01 am
- Features of the check case
- Room with Air-Conditioning Vents
- Error Floating Point Exception
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Heat transfer radiation through glass
- real fundamental difference in true tension body and engineered tension
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Viscous Models
- Convergency in mass flow rate
- Torsion Stiffness
7742
4502
2961
1449
1322
