Equivalent stress (von Mises) is higher than the yield strength
    • imselva26
      Dear all,
      In order to understand, the Equivalent stress values, I have reduced my model with just 3 parts.
      It has a heating pipe, to which electricty is supplied and it is heated. The heating pipe is surrounded by insulator. The heating pipe is heated to 850 °C.
      Now I want to do the structural analysis, the bottom of the heating pipe is given an external displacement (all the values are zero). The deformation I got is around 4.5 mm and the Equivalent Von mises stress is over 100Mpa.
      I just want to understand, why this is hapennig? Is it because of the material properties? or is it because of the boundary conditions?
      It is a very simple geomentry, and I wish to get the Equivalent stress well below 3.4Mpa which is given in the material data sheet.
      Thank you
    • Ashish Khemka
      nnThe high stress appears to be becaue of thermal condition applied.nnRegards,nAshish Khemkan
