Erosion Wear Estimation Simulation Result Vs Experimental Result
    • manvendrayadav
      I have created a solid particle erosion wear model in explicit dynamics  to estimate the mass loss of the plate due to multiple ball impact on the plate.
      In the user defined result I used Expression = Erosion and get some results. I have also exported results in excel file and values indicated as 0, 1 and in some cases 0 and 2.
      I am unable to understand the meaning of these values.
      I have to compare the simulation result and experimental result for wear.
      Please guide me about the same.
      Screen shot and result file is attached here
    • manvendrayadav
      Erosion
    • Wenlong
      Erosion=0 means not eroded, Erosion >0 means eroded
      For more detailed information, please refer to this page of Ansys help: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/exd_ag/ds_user_defined_exp_dynamics.html
      If you have trouble accessing the Ansys help, please refer to: https://studentcommunity.ansys.com/thread/how-to-access-the-ansys-online-help/
      If you have trouble seeing the full resolution image, please refer to: https://studentcommunity.ansys.com/thread/retrieving-full-resolution-images-from-posts/
      Wenlong
      Wenlong
    • manvendrayadav
      Thank you sir
      After knowing the eroded elements my interest is to know the volume of the single element. How can I calculate the volume of single element ??
      Thanking You
    • Mike Rife
      @manvendrayadav  Wear and element erosion are normally quite different in terms of amount of material removal.  If you want to actually wear, then you may want to investigate either a time transient solution with the Mechanical APDL solver (Mechanical is the pre/post processor).  Wear can be added to a contact pair.  Or if the model is best solved with an explicit code then Workbench LS-Dyna can also include wear.
    • manvendrayadav
      @mrife Thank You !!
      My interest is to estimate the loss of material of a plate due to the impact of several impact of the particles.
      With Regards
Viewing 5 reply threads
