    • santrondela
      An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.  Please see the Troubleshooting section of the Help System for more information
    • peteroznewman
      Google search on "internal solution magnitude limit was exceeded"  Read those for different ways to resolve that issue.
      The other message says to make sure there are at least two elements through the thickness of any thin solid.
