January 29, 2021 at 11:30 am
rg
SubscriberHello If you start SpaceClaim as administrator, drag and drop does not work Best Regards🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
January 29, 2021 at 11:59 am
Naresh Patre
Ansys EmployeeHello Roberto
This behavior seems to be consistent with older versions, so I guess it is intended.Â
Is there any particular reason for starting SpaceClaim as administrator? We generally recommend to run the installer in admin mode and not run the application itself.
January 29, 2021 at 1:44 pm
rg
SubscriberHello Naresh Patre
thank you i I understand
Best REgards
3730
2570
1783
1236
594
