October 20, 2020 at 2:22 pm
October 21, 2020 at 2:35 am
Charudatta Bandgar
SubscriberHello Robert ,
Will it be possible for you to share the file with me so that I will see if it happens on my end as well.
I wanted to know a few things to understand this better, Do you face this problem while saving the assembly or it only happens when you do the Share>As file option?
I think what is happening is that SC has some sort of memory of files in a certain place and it isn't getting rewritten. Or it could be a file corruption example. Should be fixable by re-saving the assembly.
Maybe you can try internalize all to force all the geometries into one file, thereby eliminating external connection?
Let me know, I will share the secure transfer link so that you can send the file.
Regards.
October 21, 2020 at 6:46 am
rg
SubscriberCharudatta Bandgar Hello
This problem only happens when I use the Share> As File option.
I don't think I can share the file, I have to ask the customer I'll let you know.
Now I will try to make all the internal components
Best Regards
October 21, 2020 at 6:56 am
Charudatta Bandgar
SubscriberThanks, Robert
Let me know if internalize all option helps.
Regards.
October 22, 2020 at 7:23 am
rg
SubscriberHello Charudatta Bandgar
I have tried to fix all the damaged geometry and now when I run the geometry check it tells me that everything is fine.
Now when I use the share as file command it does not give me any errors, but the folder that creates me in the specific path I choose is empty why?
What can it be?Best Regards
October 22, 2020 at 7:36 am
Charudatta Bandgar
Is there a way the file can be sent to investigate more?
Regards.
October 22, 2020 at 8:36 am
rg
Could you send me a secure link that I will send you the file?
Best Regards
October 23, 2020 at 9:43 am
rg
I have another question, the file takes a while to open there is no way to reduce the time?
We tested with two different PCs to open the drawing we sent you.
PC Specifications 1:
Intel I7-9700 CPU
Quadro GPU P1000
32 Gb RAM
PC 2 Specifications:
Intel I7-10750H CPU
GTX 1660 TI GPU
RAM 16 GbWe opened the drawing from the server with HDD time PC1 6.5 min - PC2 6 min.
We have replaced the server HD with an SSD time PC1 6.5 min - PC2 6 min.
We moved the whole drawing to a NAS time PC1 6.5 min - PC2 6 min.
We moved the file to local time PC1 5 min - PC2 5.5 min.
By opening the drawings with the files locally we found that the CPU does not exceed 20%, the RAM does not exceed 20%, the disk does not exceed 2%.
At this point we ask ourselves why the software does not use all the computing power of PCs and takes less time to open the drawings.
Can it be resolved somehow?
Is there any particular setting to use?Best Regards
October 23, 2020 at 10:59 am
Charudatta Bandgar
SubscriberYes, Robert .
Even for me it took a very long time to open and crashed once. I will let you any information as soon as possible. And I also noticed that it is not using the RAM more to speed up this process.
Regards.
October 23, 2020 at 12:24 pm
rg
when you know could you give me technical information about what SpaceClaim uses to open files?
It seems to me that you mostly use the GPU but let me know some information.As for the time with which it opens the file in my opinion it is normal as it is an assembly with a lot of data
Best Regards
October 26, 2020 at 9:29 am
Charudatta Bandgar
I have conveyed the information, I will let you as soon as possible.
October 26, 2020 at 10:52 am
rg
SubscriberCharudatta Bandgar Hello Charudatta
From the tests I am doing it seems to be a little faster opening the file using OpenGl, you could always ask the developers if it is better to use direct11 or Opengl?
It also seemed to me that SpaceClaim uses very little GPU and CPU for opening filesBest Regards
November 30, 2020 at 4:18 am
Charudatta Bandgar
SubscriberHello Roberto ,
Here is the explanation I received from the developers, that not all of SpaceClaim is multi-threaded, and so it doesn't always use all the power available on multi-core PCs. Loading .scdoc files is mostly single or dual-threaded, so it will use the equivalent of one or two cores, which will be around 20% CPU usage on a 6 / 12 core machine like the Intel I7-10750H on this user's machine.
Regards.
October 26, 2020 at 9:23 am
Charudatta Bandgar
Which file are you using, I am still facing issues opening it. (from the .rar file you've shared)
October 26, 2020 at 9:47 am
rg
To open the assembly I use the file called assembly
Best Regards
October 26, 2020 at 9:50 am
Charudatta Bandgar
SubscriberYes I used the same, Roberto
Thanks.
October 26, 2020 at 9:51 am
rg
I try to postpone on the same secure link
Best Regards
October 26, 2020 at 10:27 am
Charudatta Bandgar
SubscriberI will retry, Roberto
October 27, 2020 at 4:42 pm
rg
were you able to open the new file?
Best Regards
October 28, 2020 at 3:13 am
Charudatta Bandgar
SubscriberYes Roberto
I was able to open it, but not share it as a zip file. I tried internalize all option as well, but no luck.
I am in discussions with the developers for both the questions (memory usage in opening the file as well as share option for the given file.), I will let you know as soon as possible.
Regards.
November 26, 2020 at 11:12 am
rg
you have some news
Best Regards
November 27, 2020 at 4:05 am
Charudatta Bandgar
SubscriberI will get back to you, Roberto
May 5, 2021 at 9:15 am
rg
I have not received any response, it has been a while.
Often this problem occurs where the share as function cannot be usedBest Regards
May 6, 2021 at 4:54 am
Charudatta Bandgar
SubscriberRoberto I will create another bug ticket to understand it again, I have not heard back from the developers. I will let you know
3694
2564
1765
1234
590
