LS Dyna
LS Dyna
Error 70004 on running LS-Run on Student Version
    • Mach1nt0sh95
      I am learning to use LS-Dyna as preparation for my research project and have started first with the tutorials provided with the installation file.
      I've followed all the steps stated inside the folder 1.Getting_Started, and no error was found at the end prior to saving my .k file.
      However, once I proceeded with LS-Run, I encountered Termination error 70004 as attached image. This is really frustrating as there is already a discrepancy between the tutorial file and the actual LS-Run interface and settings that are available for me.
    • Ram Gopisetti
      No spaces are allowed in the input file force path remove the space between your university name and PhD.
      Cheers Ram
    • varunveeturi
      ... Iam also facing the same problem...If you have found the solution, kindly help me...iam not able to move further. Thank you in advance
