Photonics
Photonics
Error: addfdtd is not a valid function or a variable name
    • momchil
      Hi I am trying to run older scripts, and I get an error that "addfdtd is not a valid function or a variable name" -
      is addfdtd removed from MODE 2021 R1 release?
      I cannot find FDTD object under Simulation also, why is that?
    • momchil
      answering my own question - the error is due to improper project start - when running scripts with FDTD engine command (i.e. addfdtd) start the launcher and open a "New FDTD Project".
      The error was due to my MODE application starting the default project with EME solver instead.
    • Guilin Sun
      You are right that if you use script you will need to launch the proper project first. If you manually open a new project from "File", you will be able to open any solver from the launcher as the recent a few versions have this compacity.
