January 31, 2022 at 1:35 pm
Ben_Ben
SubscriberI successfully ran my model in batch mode.
February 1, 2022 at 2:06 pmBen_Ben
SubscriberI have just re run the simulation in batch mode and no longer have the issue. Not sure what happened. But all working now.
February 1, 2022 at 5:06 pmMickMack
SubscriberHi I am not an expert but i will endeavour to assist you.
Firstly i notice your output file only shows moment convergence, i do not know what you are modelling but i would expect to see force and displacement convergence values in my own results,as highlighted below.
If i was trying to resolve this i would ensure all the output controls are turned on in analysis setting. Then i would review all my boundary conditions and material properties. If there is nothing obvious i would either create another new model ensuring that everything is correct or/and create a simplified model of a simple structure to reduce the number of variables and to try and isolate the problem.
I hope this provides some help, best of luck.
3866
2639
1859
1260
606
