March 19, 2021 at 5:57 pm
Noah2021
SubscriberI am collecting data for a mathematical model for an IPM motor.
March 24, 2021 at 2:57 pmHoward
Ansys EmployeeHello Noah2021,n The MotorCAD could not run if the geometry has an issue. From the enclosed picture, I find there may be a conflict in rotor geometry.n I suggest to check the critical geometry like min. stator ID and max. air gap. and verify the geometry that we can use to build the model for all the variations. Thanks.nnBest regardsnn n nViewing 1 reply thread- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2700
2138
1355
1142
462
