March 13, 2022 at 1:01 pm
gerardsoldevilla99
SubscriberHi, everybody, I am facing a problem with my CAD design that I can't solve. I am designing some geometry with space claim, I need to record it with block recording in order to be able to modify it several times after it. The geometry was initially correct, and no error appeared, I could even run many simulations with it and modify some parameters. But now that I am trying to edit some blocks, I found an error that doesn't let me even see the geometry.
March 14, 2022 at 4:25 pmAniket
Ansys Employeewere you importing any file at start of the block? Can you access that file ?
-Aniket
March 14, 2022 at 4:33 pmgerardsoldevilla99
SubscriberThank you for your interest. The full folder was copied from another folder, and then I continued adding blocks and designing different parts of the geometry, then I imported a file and inserted it, but it was after that, the error is appearing just at the start block, not in the import block.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
