December 23, 2022 at 4:36 am
Ruud Boon
SubscriberWe updated this week from 2022R1 to 2022R2
We use Spaceclaim since 2017 version and always used the insert Symbol. we didn't have any problems with updating till now. All computers have the same problem. We cant place a symbol.
I tried already a lot of things.
- Symbol with only text.
- Make new symbol libary document instead of the old one.
- Place libary on the C drive instead of the netwerk.
- Did a fresh new installation
- Put off the pluginsIs this a bug or can i fix this?
Log file is showing this message:
No SpaceClaim updates available.
08:48:39: start load Y:SpaceClaim1 - 3D-Templatestest3.scdoc
08:48:39: ended load Y:SpaceClaim1 - 3D-Templatestest3.scdoc
Ansys PlugInMgr failed: Failed to create object 412c6df4-76f3-4aa4-8d47-abb223ff7954
File is Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
08:48:49: start load Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
08:48:49: ended load Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
An exception occurred in the Execute method of UICommand 'SelectBlock_x_2_0': Value cannot be null.
Parameter name: def
Exception occurred: (System.ArgumentNullException) Value cannot be null.
Parameter name: def
Exception Traceback: at SpaceClaim.EvalContext.GetParent(IDefinition def)
at SpaceClaim.Block.get_Parent()
at SpaceClaim.BlockManager.GetBlockIndex(IBlock block)
at SpaceClaim.CoreCommandContainer.selectBlockCommand_Execute(Object sender, UICommandEventArgs e)
at SpaceClaim.UICommands.UICommand.OnExecute(Object sender, EventArgs e, Boolean calledFromTheApi)CAInit: 0
December 23, 2022 at 4:51 am
Ruud Boon
SubscriberFound this question it is the same.
https://discoveryforum.ansys.com/t/x2h0hm1/bug#y4h0h9s -
December 23, 2022 at 7:25 am
Charudatta Bandgar
Forum ModeratorHello Ruud
Filed a bug ticket 760789. Will update on this post, as I hear back from the development.
Regards
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8700
4658
3151
1672
1446
