January 16, 2023 at 11:05 am
babak.aghel
SubscriberI am using Fluent 2020 R1 on a Windows 10 Education to run a 3D transient circulating fluidized bed simulation. I created a UDF to predict the flow behavior for each cell in the simulation.
Until last week, the UDF source code worked without any problems, but today it has failed. The issue I am having is when I try loading the UDF after building it, it gives me Error code: 126. Could you please help me resolve this issue?
Thank you in advance.
January 16, 2023 at 11:56 am
DrAmine
Ansys EmployeeIs it same machine? Copy the case file into a new folder. Same with the *.c file. Start Ansys Fluent, compile but do not load, then read the case file. I am assuming you are using the built-in compiler.
January 16, 2023 at 12:18 pm
babak.aghel
SubscriberYes, I am using the built-in compiler on the same machine. I followed your suggestion but It did not work.
January 16, 2023 at 12:29 pm
DrAmine
Ansys EmployeePlease update first to a recent Fluent version and try again (choosing explicelty the built-in compiler). Otherwise try using a compatible Visual Studio Compiler.
2564
2080
1299
1106
459
