August 30, 2018 at 8:18 pm
balsaidi
SubscriberI am trying to wrap 2-D shell lattice around wing of an airplane. However, after wrapping the shell, I have problem with cutting it using selected planes. Please see the attached images for clarification. Any suggestion?
Thanks,
Bashir
August 30, 2018 at 8:34 pm
Sandeep Medikonda
Ansys EmployeeBashir,
It is not clear how you plan on cutting it or why?
I don't see any intersection of the plane and the wing?
FYI, you can also use the Combine tool to cut bodies.
Sandeep
August 30, 2018 at 9:19 pm
August 30, 2018 at 9:22 pm
balsaidi
SubscriberBy the way, I tried both features, split body and combine. Non of them worked for me. The error message is "Unable to cut body".
Thanks,
Bashir
August 31, 2018 at 4:03 am
Rahul Kumbhar
Ansys EmployeeHi Bashir,
Please check the geometry for any corruption. Locate he body in structure tree, right click on it >> select 'Check Geometry'. This should show if there is any issue.
Regards
Rahul
August 31, 2018 at 9:40 am
Sandeep Medikonda
Ansys EmployeeBashir, If I understand this correctly are you trying to cut the airfoil vertically?
Is the wing completely joined even at the trailing edge?
August 31, 2018 at 10:10 pm
balsaidi
SubscriberSandeep,
Yes I was trying to cut the wing vertically to make sure that all bodies, wing and two layers of shells, are collinear. Anyway, I realized that switching between DM and SpaceClaim causes some vertexes issues.
I am expecting that the meshing issue that I face is due to the way that share topology constructed between certain faces. Would you please explain to me how to use share topology for selected bodies in SpaceClaim? I am using ANSYS R17.2
Thanks,
Bashir
August 31, 2018 at 10:22 pm
Sandeep Medikonda
Please see this post by Peter.
Also, please see this example and this help article.
Sandeep
2066
1279
1096
459
