Materials
Materials
Error: Density is required
    • far29
      I've been trying to run my simulation on transient but every time I try to solve this error pops up ( in the screenshot at the bottom right). I attached a screenshot of how I defined my material and the error.
      Please help me figure this out.
      Thanks
    • peteroznewman
      Follow the directions in the error message and add Density to the material in Engineering Data. Density is listed under Physical Properties and you drag and drop it onto your material.
      You can't run a Transient analysis on a solid body that has no Density defined, since mass is in the equations and if there is no density, there is no mass.
    • far29
      I added the density, however I am still getting the error of density being under defined?
      Thanks
    • peteroznewman
      Please insert an image showing the error message.
    • far29
    • peteroznewman
      I don't know what is wrong. Someone from ANSYS will have to reply.
Viewing 5 reply threads
