Discovery Import
Discovery Import
Error Downloading Example
    • deanna.godby
      I tried to download the solenoid example from this forum. I saved the .zip file to my computer and then extracted the files to get a .wbpz file. I opened ANSYS AIM 2019 R2 and selected open file. When I tried to open the .wbpz file, I was given an error - AnsysFWW - "ACIS libraries couldn't be found in: ". When I selected OK, the following resulted (I attached the script). How do I fix this?
      After the first error message, the following popped up: "Could not start modeler. Error: Value cannot be null. Parameter name: path1."
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello Deanna G
      Please go through the solution mentioned in attached document. Let me know if you still face issues.
