Photonics
Photonics
Error due to unexpected end of file
    • Rosmin_Elsa_Mohan
      Due to an unexpected reboot, the file I was working on cannot be opened and the error message is attached. In such a case, is there a way to retrieve the original file?  Thanks a lot Screenshot showing error
    • Guilin Sun
      It is likely this file is corrupted. Please try to convert the backup file to a normal fsp file and see if it works. You may also copy this file to a new machine .
      if both not work, then you may need to rebuid this file. I am sorry for the trouble.
