May 9, 2023 at 1:07 pm
Lukas Hildebrand
SubscriberDear community,
I coupled my EddyCurrent Design with Icepac and everything works except for Errors in the 3D Model which name as follows:
1) Duplicate Face ID (XXXXX) found in part XXX
1) Duplicate Edge ID (XXXXX) found in part XXX
1) Duplicate Vertex ID (XXXXX) found in part XXX
What does that mean and how can I resolve them?
Thanks,
Lukas
May 11, 2023 at 11:13 am
Pdev
Ansys EmployeeHi Lukas,
Could please share screen shots of this error? and is the simulation running?
Best,
Pdev -
May 24, 2023 at 4:26 am
Pine Liu
Subscriberwhat is answer?
May 24, 2023 at 7:23 am
Lukas Hildebrand
SubscriberHi Pine,
the problem was that somehow the Icepac designer did not like a specific model that was duplicated around an axis and apparently gave the same id's to the duplicated one. I solved the problem by not duplicating the model around the axis, but modeling it again the same way I designed the original model.
Hope this helps.
Lukas
- Maxwell, HFSS or Q3D?
- Error
5454
3417
2473
1310
1022
