Ansys Free Student Software
Error during ANSYS WORKBENCH Installation
    • ces182129
      HinI am trying to install ANSYS Workbench 2020 R2. I have unzipped the folder, but when I try to install the setup it gives a critical error (not responding) . Please Suggest the needful. Tried to do it several times but everytime same issue.nnThanksnVaishalin
    • ANSYS_MMadore
      Can you share a screenshot of exactly what you encounter?nThank youn
    • fpalacio
      I had the same issue.nI tried using the CMD Promt code: move %appdata%\ansys %appdata%\ansys.old. However, it did not work.nMy solution was removing all Ansys folders from the AppData folder. To do so, I had to Show Hidden Items on the Windows Explorer, then removed the Ansys folders under C:\Users\{User_name}\AppData, both Local and Roaming.nNote that I had this issue after a first unsuccessful installation of ANSYS, when I ran out of space in my hard drive.n
