December 3, 2020 at 2:57 pm
Rameez_ul_Haq
SubscriberDecember 4, 2020 at 3:12 amKeyur Kanade
Ansys EmployeeAs per message, angle between your faces is large. If they are merged, meshing will fail. So meshing is avoiding to create VT. nYou can try pinch controls. Please see help manual for more details about these commands. nBest way is to modify geometry in SpaceClaim or Design Modeler at that location so that VT is not required. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8770
4658
3151
1678
1456
