error: expression is not assignable Ansys Fluent DPM
    • pavankonchada123
      C_DPMS_YI(c,t,0) += mp_dot*dpm_relax;
      When trying to implement define_dpm_switch udf in ansys fluent above line is throwing an erro
      It is showing error: expression is not assignable.
      Please can you help me in rectifying it
      That’s the macro for species mass source from the DPM parcel. How are you planning on altering it? You may be able to augment it using a UDF. Don’t forget to remove more DPM mass if you do!
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/flu_udf/flu_udf_DataAccessMacros.html%23flu_udf_ApplicationMacros
    • pavankonchada123
      It is the same udf what is present in udf manual I am trying to implement.
      The below mentioned lines are working without throwing any error
        C_DPMS_ENERGY(c,t) -= mp_dot*dpm_relax*MATERIAL_PROP(sp,PROP_Cp)*(C_T(c,t)-298.15);
         C_DPMS_ENERGY(c,t) -= mp_dot*dpm_relax*MATERIAL_PROP(sp,PROP_latent_heat);
      And I dont understand why C_DPMS_YI(c,t,0) += mp_dot*dpm_relax; is stating not assignable
      OK, I assume species are turned on?
    • pavankonchada123
      Yes ofcourse and vapor has index 0
      Read to the bottom of the table on the link I sent - search for C_DPMS_YI on the page & then scroll down for the "Note".
Viewing 5 reply threads
