Ansys Products
Ansys Products
[error] Failed to check out license ‘m2dfs_qs_solve’. No such license exists (FLEXlm Error -5)
    • frankapdl
      I encounter an issue about the ANSYS Electronics 2019. The 2019 version can start and can build model inside, but when I click "analyze", the error message will pop up.
    • George Karnos
      I am wondering if the license file in use is the new features valid from 2020 R1 and above.
      Is it possible to try and use Version 2020 Rx or higher? If so, you may run into the following:
      https://forum.ansys.com/index.php?p=/discussion/28685/license-error-note-that-pro-premium-enterprise-licenses-are-available-on-your-server#latest
      Also, To verify, can you post the contents of the license file from your license server machine
      We are not permitted to open files, so would you be able to post the INCREMENT lines only.
    • frankapdl
      Mr. Karnos, Thank you!
      It works. 2020R1 was installed and no such problem appears.
