Error: floating point exception
    • TokarZak
      Hi, Pls help me to solve this error, wich i have after initialization.
      Initialize using the hybrid initialization method.
      Checking case topology...
      -This case has both inlets & outlets
      -Pressure information is available at the boundaries
      iterscalar-0scalar-1
              Stabilizing ads-0 to enhance linear solver robustness.
      Divergence detected in AMG solver: ads-0
      Divergence detected in AMG solver: ads-0 1 1.000000e+00 1.000000e+00
      27.069178e-151.032749e-07
      31.247592e-155.052188e-08
      42.017610e-156.174646e-09
      58.277866e-161.961420e-09
      66.685306e-166.028668e-10
      73.816698e-163.438961e-10
      82.523928e-161.602407e-10
      93.202773e-161.096430e-10
      104.077587e-165.657155e-11
      Hybrid initialization is done.
       Error at Node 6: floating point exception
      Error at Node 11: floating point exception
      Error at Node 2: floating point exception
      Error at Node 0: floating point exception
      Error at Node 7: floating point exception
      Error at Node 5: floating point exception
      Error at Node 8: floating point exception
      Error at Node 9: floating point exception
      Error at Node 1: floating point exception
      Error at Node 3: floating point exception
      Error at Node 10: floating point exception
      Error at Node 4: floating point exception
      Error at host: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error Object: #f
      Mesh Check
      Domain Extents:
         x-coordinate: min (m) = -3.284205e-01, max (m) = 9.376061e-01
         y-coordinate: min (m) = -1.214897e+00, max (m) = 1.214805e+00
         z-coordinate: min (m) = -1.300000e+00, max (m) = 1.214776e+00
       Volume statistics:
         minimum volume (m3): 3.039545e-15
         maximum volume (m3): 2.135412e-04
           total volume (m3): 2.186046e+00
       Face area statistics:
         minimum face area (m2): 5.922891e-12
         maximum face area (m2): 3.296252e-03
       Checking mesh.....................................
      Done.
    • TokarZak
      Also i am add the pictures, where i apply BC to model.
    • Mostafa22
      dear TokarZak,
      I think for your model, you have some fine contact regions. So in the mesh interfaces, you can modify these contact regions into a coupled wall and mapped as well as check the material properties.
      I wish these suggestions help you
      regards,
      mostafa
    • Keyur Kanade
      The image is not so clear.
      If you have those contact regions -
      Go back to design modeler. Select all bodies  in the model tree and create a single part. This will give conformal mesh between different bodies.
      Then mesh it and then come to fluent.
    • Keyur Kanade
      Also please check quality of the mesh. The min ortho quality should be more than 0.1.
      The min volume is very less. So pleas use double precision.
    • seeta gunti
      I guess solver is diverging in UDS. Please run the continuity and momentum equations first. After flow gets stabilized, turn on UDS.  Reduce the URFs and initially run with first order then change to second order.
      Seeta
    • TokarZak
      Hi, thaks a lot for response. But i dont use UDS.
    • DrAmine
      Could you please elaborate on your problem physics and problem setup?
    • TokarZak
      Hi, i have really big model, but with simple setup: Without Energy eq. viscous model is laminar. I was set pressure on inlet and out let, choose material like water-vapor.
      i will add link for CASE:
      https://drive.google.com/open?id=1JXFRIWzWPdkpLnpkHPGe8g0M2hDXItQq
      Best regards
      Zak
    • TokarZak
      Ok, It was solved. Thanks a lot.
    • Keyur Kanade
      can you please mark this as 'Is Solution' to help others on forum.
    • aliazzam
      what was the solution please ????????
    • aliazzam
      how did u do it please ???
      Please post in a new thread with details of your problem.
Viewing 13 reply threads
