October 23, 2018 at 1:02 am
krany3
SubscriberError: GENERAL -CAR-CDR: invalid argument [1]: improper list
Error Object : #f
I'm always getting this error after each session. What to do? Even I tried a couple of solutions mentioned in the community. But, they did not solve my issue.
October 23, 2018 at 8:39 am
Ansys EmployeeI assume you're using Fluent. The error means there is a data mismatch and something isn't compatible, or more likely filled in. Which version are you using, and what models are turned on?
October 23, 2018 at 12:51 pm
krany3
SubscriberYes, I'm using Fluent of version 18.1. Whenever I create a plane in Fluent for a contour, it's showing that error. How do I solve this issue -
October 23, 2018 at 1:54 pm
Ansys EmployeeAre you creating a plane, or an isosurface? If it's the former check the definition is valid (it's easy to muck up the order of the corners). If I'm creating a surface for post processing I use isosurfaces of mesh.
October 23, 2018 at 7:26 pm
krany3
SubscriberI'm creating the plane. I'll try your suggestion. Thank you. -
October 29, 2018 at 11:15 pm
krany3
SubscriberI'm unable to open the Fluent. I keep on getting the same error. Even I tried to load the case and data files. But, it's showing the same error. Can you help me to resolve this issue?
October 30, 2018 at 6:01 am
seeta gunti
Ansys EmployeeHi,
suggestion 1: Start a new fluent and load the case and data files. You export the data to CFD-POST and do the post processing in CFD-POST.
Suggestion 2: start a new fluent, load the case and data files. Go to contours and select the variable to plot and select any surface and compute. Check whether it is computing or not. If it is computing, you can create a new surface from iso-surface of mesh and plot it.
Seeta
October 30, 2018 at 3:29 pm
krany3
SubscriberThanks. I've already done with your suggestions. The issue is, I'm getting the above mentioned error. Because of that, Fluent is not reading the files. -
October 30, 2018 at 5:38 pm
krany3
SubscriberHow should I overcome the ERROR? Fluent doesn't read the case and data files. It just gives an error
Error Object : #f
October 31, 2018 at 3:27 pm
Ansys EmployeeYou should be able to read the case unless it's completely messed up. If you can't read into standalone Fluent, read it into Fluent with the meshing option ticked. Once there, use the Transfer to Solution button: if you're lucky it'll open and you can hunt though the settings to find what's causing the issue. Note, if you do need to go via the Fluent meshing route the data may not be usable.
October 31, 2018 at 6:07 pm
krany3
SubscriberThank you
2524
2066
1279
1096
459
