Photonics
Photonics
Error High-Q cavity
    • gmartinezdearriba1
      I am trying the High Q analysis object https://optics.ansys.com/hc/en-us/articles/360041611774-Quality-factor-calculations-for-a-resonant-cavity, but i cannot see the spectrum, it seems that the data is empty ("parameter consist of at least one undefined or infinite value"). The freqyuency data is there, but I would like to see the wavelength.
    • Guilin Sun
      Do you mean your downloaded file fails? which software version you are using? I downloaded and tested for both file without issue:
      YOu can edit the analysis group, and check which line it has problem and modify it :
      you may need to download and install the newest version of FDTD.
