Ansys Products
Ansys Products
Error in Ansys CFX Solver
    • cfdshark
      Hi, I am new to Ansys and trying out this tutorial from YouTube on the 2023 R1 version (CFX fluid). I run into these errors: (I uninstalled Ansys and re-installed it but the same errors persist, I attempted every solution I could find on the all-knowing Oracle, Google but to no avail)
      The ANSYS CFX solver exited with return code 1.
      Update failed for the Solution component in Fluid Flow (CFX). The solver failed with a non-zero exit code of : 2
      I've put the tilde in the place of my license ID
      This run of the CFX 2023 R1 Solver started at 04:11:12 on 12 Jun 2023
      by user user on ~ (intel_xeon64.sse2_winnt) using the
      command:
      "C:\Program Files\ANSYS Inc\ANSYS Student\v231\CFX\bin\perllib\cfx5solve.pl"
      -batch -ccl runInput.ccl -fullname "Fluid Flow CFX_001"
      2023 R1
      Point Releases and Patches installed:
      Discovery 2023 R1
      Autodyn 2023 R1
      SpaceClaim 2023 R1
      CFX (includes CFD-Post) 2023 R1
      Chemkin 2023 R1
      EnSight 2023 R1
      FENSAP-ICE 2023 R1
      Fluent (includes CFD-Post) 2023 R1
      Polyflow (includes CFD-Post) 2023 R1
      Forte (includes EnSight) 2023 R1
      TurboGrid 2023 R1
      Aqwa 2023 R1
      Speos 2023 R1
      Mechanical Products 2023 R1
      Material Calibration App 2023 R1
      ACIS Geometry Interface 2023 R1
      AutoCAD Geometry Interface 2023 R1
      Catia, Version 4 Geometry Interface 2023 R1
      Catia, Version 5 Geometry Interface 2023 R1
      Catia, Version 6 Geometry Interface 2023 R1
      Creo Elements/Direct Modeling Geometry Interface 2023 R1
      Creo Parametric Geometry Interface 2023 R1
      Inventor Geometry Interface 2023 R1
      JTOpen Geometry Interface 2023 R1
      NX Geometry Interface 2023 R1
      Parasolid Geometry Interface 2023 R1
      Solid Edge Geometry Interface 2023 R1
      SOLIDWORKS Geometry Interface 2023 R1
      Academic Student 2023 R1
      Setting up CFX Solver run ...
      | CFX Command Language for Run |
      LIBRARY:
      MATERIAL: Air at 25 C
      Material Description = Air at 25 C and 1 atm (dry)
      Material Group = Air Data, Constant Property Gases
      Option = Pure Substance
      Thermodynamic State = Gas
      PROPERTIES:
      Option = General Material
      EQUATION OF STATE:
      Density = 1.185 [kg m^-3]
      Molar Mass = 28.96 [kg kmol^-1]
      Option = Value
      END
      SPECIFIC HEAT CAPACITY:
      Option = Value
      Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
      Specific Heat Type = Constant Pressure
      END
      REFERENCE STATE:
      Option = Specified Point
      Reference Pressure = 1 [atm]
      Reference Specific Enthalpy = 0. [J/kg]
      Reference Specific Entropy = 0. [J/kg/K]
      Reference Temperature = 25 [C]
      END
      DYNAMIC VISCOSITY:
      Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
      Option = Value
      END
      THERMAL CONDUCTIVITY:
      Option = Value
      Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
      END
      ABSORPTION COEFFICIENT:
      Absorption Coefficient = 0.01 [m^-1]
      Option = Value
      END
      SCATTERING COEFFICIENT:
      Option = Value
      Scattering Coefficient = 0.0 [m^-1]
      END
      REFRACTIVE INDEX:
      Option = Value
      Refractive Index = 1.0 [m m^-1]
      END
      THERMAL EXPANSIVITY:
      Option = Value
      Thermal Expansivity = 0.003356 [K^-1]
      END
      END
      END
      END
      FLOW: Flow Analysis 1
      SOLUTION UNITS:
      Angle Units = [rad]
      Length Units = [m]
      Mass Units = [kg]
      Solid Angle Units = [sr]
      Temperature Units = [K]
      Time Units = [s]
      END
      ANALYSIS TYPE:
      Option = Steady State
      EXTERNAL SOLVER COUPLING:
      Option = None
      END
      END
      DOMAIN: Default Domain
      Coord Frame = Coord 0
      Domain Type = Fluid
      Location = B186, B98
      BOUNDARY: inlet
      Boundary Type = INLET
      Location = F30.98
      BOUNDARY CONDITIONS:
      FLOW REGIME:
      Option = Subsonic
      END
      MASS AND MOMENTUM:
      Normal Speed = 40 [km hr^-1]
      Option = Normal Speed
      END
      TURBULENCE:
      Option = Medium Intensity and Eddy Viscosity Ratio
      END
      END
      END
      BOUNDARY: opening
      Boundary Type = OPENING
      Location = F26.98,F28.98,F29.98
      FLOW DIRECTION:
      Option = Normal to Boundary Condition
      END
      FLOW REGIME:
      Option = Subsonic
      END
      MASS AND MOMENTUM:
      Option = Opening Pressure and Direction
      Relative Pressure = 0 [Pa]
      END
      TURBULENCE:
      END
      END
      END
      BOUNDARY: outlet
      Boundary Type = OUTLET
      Location = F31.98
      FLOW REGIME:
      Option = Subsonic
      END
      MASS AND MOMENTUM:
      Option = Average Static Pressure
      Pressure Profile Blend = 0.05
      END
      PRESSURE AVERAGING:
      Option = Average Over Whole Outlet
      END
      END
      END
      BOUNDARY: wall
      Boundary Type = WALL
      Location = \
      F139.186,F140.186,F141.186,F142.186,F143.186,F144.186,F145.186,F146.1\
      86,F147.186,F163.186,F164.186,F166.186,F168.186,F169.186,F171.186,F17\
      3.186,F181.186,F182.186,F183.186,F187.186,F188.186,F189.186,F27.98,F3\
      2.98,F33.98,F34.98,F35.98,F36.98,F37.98,F38.98,F39.98,F40.98,F41.98,F\
      42.98,F43.98,F44.98,F45.98,F46.98,F47.98,F48.98,F49.98,F50.98,F51.98,\
      F52.98,F53.98
      MASS AND MOMENTUM:
      Option = No Slip Wall
      END
      WALL ROUGHNESS:
      Option = Smooth Wall
      END
      END
      END
      DOMAIN MODELS:
      BUOYANCY MODEL:
      Option = Non Buoyant
      END
      DOMAIN MOTION:
      Option = Stationary
      END
      MESH DEFORMATION:
      Option = None
      END
      REFERENCE PRESSURE:
      END
      END
      FLUID DEFINITION: Fluid 1
      Material = Air at 25 C
      Option = Material Library
      MORPHOLOGY:
      Option = Continuous Fluid
      END
      END
      FLUID MODELS:
      COMBUSTION MODEL:
      Option = None
      END
      HEAT TRANSFER MODEL:
      Fluid Temperature = 25 [C]
      Option = Isothermal
      END
      THERMAL RADIATION MODEL:
      Option = None
      END
      TURBULENCE MODEL:
      Option = SST
      END
      TURBULENT WALL FUNCTIONS:
      Option = Automatic
      END
      END
      END
      OUTPUT CONTROL:
      RESULTS:
      File Compression Level = Default
      Option = Standard
      END
      END
      SOLVER CONTROL:
      Turbulence Numerics = First Order
      ADVECTION SCHEME:
      Option = High Resolution
      END
      CONVERGENCE CONTROL:
      Length Scale Option = Conservative
      Maximum Number of Iterations = 100
      Minimum Number of Iterations = 1
      Timescale Control = Auto Timescale
      Timescale Factor = 1.0
      END
      CONVERGENCE CRITERIA:
      Residual Target = 1.E-4
      Residual Type = RMS
      END
      DYNAMIC MODEL CONTROL:
      Global Dynamic Model Control = On
      END
      INTERRUPT CONTROL:
      Option = Any Interrupt
      CONVERGENCE CONDITIONS:
      Option = Default Conditions
      END
      END
      END
      EXPERT PARAMETERS:
      topology estimate factor = 1.0
      END
      END
      COMMAND FILE:
      Version = 23.1
      Results Version = 23.1
      END
      SIMULATION CONTROL:
      EXECUTION CONTROL:
      EXECUTABLE SELECTION:
      Double Precision = No
      Large Problem = No
      END
      INTERPOLATOR STEP CONTROL:
      Runtime Priority = Standard
      MEMORY CONTROL:
      Memory Allocation Factor = 1.0
      Option = Model Based
      END
      END
      PARALLEL HOST LIBRARY:
      HOST DEFINITION: ~
      Remote Host Name = ~
      Host Architecture String = winnt-amd64
      Installation Root = C:\Program Files\ANSYS Inc\ANSYS Student\v%v\CFX
      END
      END
      PARTITIONER STEP CONTROL:
      Multidomain Option = Automatic
      MEMORY CONTROL:
      END
      PARTITION SMOOTHING:
      Maximum Partition Smoothing Sweeps = 100
      Option = Smooth
      END
      PARTITIONING TYPE:
      MeTiS Type = k-way
      Option = MeTiS
      Partition Size Rule = Automatic
      END
      END
      RUN DEFINITION:
      Run Mode = Full
      Solver Input File = Fluid Flow CFX.def
      Solver Results File = \
      C:/Users/user/AppData/Local/Temp/WB_user_18340_2/wbnew_pending/dp0_\
      CFX_Solution/Fluid Flow CFX_001.res
      END
      SOLVER STEP CONTROL:
      MEMORY CONTROL:
      END
      PARALLEL ENVIRONMENT:
      Number of Processes = 1
      Start Method = Serial
      END
      END
      END
      END
      | Solver |
      | ANSYS(R) CFX(R) Solver |
      | 2023 R1 |
      | Build 23.1 2022-11-25T14:31:12.124816 |
      | Fri Nov 25 16:32:25 GMTST 2022 |
      | Executable Attributes |
      | single-64bit-int32-archfort-optimised-std-lcomp |
      | (C) 1996-2023 ANSYS, Inc. |
      | All rights reserved. Unauthorized use, distribution or duplication |
      | is prohibited. This product is subject to U.S. laws governing |
      | export and re-export. For full Legal Notice, see documentation. |
      | Job Information at Start of Run |
      Run mode: serial run
      Host computer: ~
      Job started: Mon Jun 12 04:11:16 2023
      | License Information |
      License Cap: ANSYS CFD Solver
      License ID: ~
      INFO: You are using an academic student license which enables meshes
      up to 512000 vertices.
      INFO: Your license enables 4-way parallel execution.
      For faster simulations, please start the application with the
      appropriate parallel options.
      | Initial Memory Allocation (Actual usage may vary) |
      | Real | Integer | Character | Logical | Double
      Mwords | 12.70 | 3.83 | 9.30 | 0.12 | 0.47
      Mbytes | 48.46 | 14.63 | 8.87 | 0.46 | 3.60
      | Host Memory Information (Mbytes): Solver |
      | Host | System | Allocated | % |
      | ~ | 12167.33 | 76.02 | 0.62 |
      | ****** Notice ****** |
      | One or more expert parameters have been enabled. Note that expert |
      | parameters are intended for use only by customers who are |
      | experienced in the use of CFX, or who have been instructed to use |
      | them by ANSYS Customer Support. Use of the parameters is not fully |
      | supported, and may have unexpected or unintended consequences both |
      | for the quality of results and the performance of the CFX-Solver. |
      | Topology Simplification |
      | ****** Warning ****** |
      | Topology simplification is activated with the following |
      | restrictions: |
      | - Mesh regions referenced only within User Fortran and NOT |
      | in the command file will cause the solver to stop. |
      | - The solver will stop during any "Edit Run in Progress" step |
      | if new 2D regions are referenced. |
      | Mesh Statistics |
      | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio |
      | | Minimum [deg] | Maximum | Maximum |
      | Default Domain | 3.4 ! | 6807 ! | 48 OK |
      | | %! %ok %OK | %! %ok %OK | %! %ok %OK |
      | Default Domain | <1 1 99 | <1 4 96 | 0 0 100 |
      Domain Name : Default Domain
      Total Number of Nodes = 15276
      Total Number of Elements = 77322
      Total Number of Tetrahedrons = 77322
      Total Number of Faces = 9126
      | Average Scale Information |
      Global Length = 8.9411E-02
      Minimum Extent = 5.8849E-02
      Maximum Extent = 1.4100E-01
      Density = 1.1850E+00
      Dynamic Viscosity = 1.8310E-05
      Velocity = 1.1111E+01
      Advection Time = 8.0470E-03
      Reynolds Number = 6.4295E+04
      | Checking for Isolated Fluid Regions |
      2 isolated fluid regions were found in domain Default Domain
      If the isolated regions do not have the pressure level set either
      by the boundary conditions or using a reference pressure equation,
      you may encounter severe robustness problems.
      This situation may have arisen because a domain interface was not
      properly defined during problem setup. Please carefully check
      the setup.
      The solver will stop now and write a results file. The isolated
      regions can be visualised in CFX Post by making plots of the
      variable "Isolated Volumes".
      If you are sure that the pressure level is set in each isolated
      fluid region then you can force the solver to turn off this check
      by setting the expert parameter "check isolated regions = f".
      | Host | System | Peak | % |
      | ~ | 12167.33 | 105.42 | 0.87 |
      | CPU Time Requirements of Solver |
      File Reading 8.41E-01 29.0 %
      Variable Updates 1.90E-02 0.7 %
      File Writing 2.01E-01 6.9 %
      Miscellaneous 1.84E+00 63.4 %
      Total 2.90E+00
      | Job Information at End of Run |
      Host computer: DESKTOP-T14J19H (PID:3952)
      Job finished: Mon Jun 12 04:11:19 2023
      Total wall clock time: 2.287E+00 seconds
      or: ( 0: 0: 0: 2.287 )
      ( Days: Hours: Minutes: Seconds )
      | An error has occurred in cfx5solve: |
      | The ANSYS CFX solver exited with return code 1. |
      End of solution stage.
      | The results from this run of the ANSYS CFX Solver have been |
      | written to |
      | C:/Users/user/AppData/Local/Temp/WB_user_18340_2/wbnew_pending/- |
      | dp0_CFX_Solution/Fluid Flow CFX_001.res |
      | The following user files have been saved in the directory |
      | dp0_CFX_Solution/Fluid Flow CFX_001: |
      | mon |
      | For CFX runs launched from Workbench, the final locations of |
      | directories and files generated may differ from those shown. |
      This run of the ANSYS CFX Solver has finished.
    • Supreetha J
      Kindly refer to the forum discussion: Error in Ansys CFX Solver
      Hope the issue is resolved.
      Thank you.
