Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Error in Ansys Electronics
    • OlhA Dubinina
      Please help me, what kind of error is this? What should I do? does not count any process
    • Ivonne Marti
      Hi OlhA,
      Please find below for the list of the usual culprits for this “COM engine” issue:
      1. Verify that CPU and RAM were not at 100% at the time of the error message. Also make sure that hyperthreading is disabled.
      2. Ask IT to add security (anti-virus, firewall, etc.) exceptions to AnsysEM folder to ensure that they don't interfere with ANSYS processes.
      3. Don’t connect to both Wi-Fi and LAN at the same time and don’t switch network.
      4. Don't connect to VPN or connect, then disconnect. If connect, then disconnect, please reboot or run:
      ipconfig /release
      then
      ipconfig /renew
       5. Try extending licensing timeout by setting FLEXLM_TIMEOUT=10000000 environment variable
       6. Check with IT if there was network instability around the time of error message
      I hope it helps you. Ivonne
