Error in ANSYS Fluent
    • Rajveer7
      Here I am performing analysis through ANSYS Fluent,  in which air is passed over the cylinder to study Drag, Lift & other effects (Von-Karma). But this error is coming over & again. I tried uninstalling & re-installing ANSYS but it's not making any good. Please look into it and revert back at earliest.
      Error Discription
    • DrAmine
      Quick Help: try to run the case outside of the workbench. Under Start-Programs and launch Fluent. It seems you have an issue with archiving the project: Check if you still have space on the temporary folder (and the permissions). If this is not the cause: check the installation log files if any error has been reported.
    • Rajveer7
      Space is quite abundant in all the drives, I didn't face any problem while installation or post-installation also. Any other way out to solve this error.
      Waiting for a quick reply.
      Rajveer Panesar
      Can you post the path you're trying to write to? I assume there aren't any "odd" characters in that or the machine name?
    • Rajveer7
      I solved it, there was some error while installation. I did something wrong in ANSYS License Manager. Performed Reset of entire PC and then re-installed ANSYS 18.2. Bingo it worked out!
      Thanks, everyone who tried to help.
      Cheers,
      Rajveer
Viewing 4 reply threads
