January 6, 2018 at 9:13 am
Rana Nasser
SubscriberI'm doing an illustrative example on ansys fluent that simulates laminar pipe flow. After generating the mesh and the named section this error appeared " received a fatal signal (segmentation fault)",then the project update fails. can anyone help?
January 8, 2018 at 6:43 am
Vishal Ganore
Ansys EmployeePlease attach your project file (.wbpz)
January 8, 2018 at 11:05 am
Rana Nasser
Subscriberhow can I attach the file?
Raef.Kobeissi
SubscriberDid you try to reset the solution stage and re-introduce the mesh into Fluent? As Vishal said, it wouldbe great if you can attached the whole project file or send some pics.
Best Regards
January 8, 2018 at 11:10 am
Raef.Kobeissi
SubscriberThere should be an Attach button on the right hand side of your last post.
Regards
2644
2110
1335
1112
461
