Error in Aqwa time domain simulation
    • Vishnu R.
      Hello everyone,
      I am practicing Aqwa using the student version. I ran the diffraction solver for a ship shaped model with forward speed of 10 knots. This is the first time I am running a simulation with forward speed, in any software. The solver completed successfully. Then I ran a time domain simulation for irregular wave response in 180 deg waves with a PM spectrum (Hs-3m, Tz-8s). I faced the following issues. Hoping someone would be patient enough to read through them.
      1. Even though the simulation completed successfully, when I checked the Animation it showed that the vessel capsized after few time steps and the rest of the simulation was completed in this capsized position. I tried to solve this by deactivating the Y, RX and RZ freedoms. Of course the model did not capsize this time, but what am I missing here? Why did it capzise in a simulation in head seas? Also, this method revealed my next issue.
          2. In the animation, the model is moving backwards even though the diffraction was run with a forward speed. Probably my understanding is wrong here. Does giving a forward speed actually simulate the vessel to move forward or it only solves the diffraction problem for the corresponding encounter frequencies? So, is the model moving backwards because of the steady drift in 180 deg waves?
          3. I found a possible work around (suggested by someone) which is to define a Structure Force in the +ve X direction for the entire duration of the simulation (3 hrs). I ran the simulation this way and it seemed to be working (while later looking at the TIMERESPONSE.LIS file) until the solver aborted at 10206 sec. Please see the error messages in the attached image. It says the time step 0.1 sec is too big. What is the appropriate time step? Did the structure force cause any issue? Was it the right method anyway, to make the model move forward?
      Thanks in advance.
    • Mike Pettit
      Hello Vishnu,
      To answer your questions:
      1. Please add a Hydrostatic result to the Hydrodynamic Diffraction Solution, and check the Metacentric Height (GMX) that has been calculated for the vessel - naturally this should be positive. Also check the calculated CoG, CoB, displacement etc. for any unexpected values. I would not recommend deactivating rotational freedoms to prevent the vessel from capsizing.
      2. Defining a forward speed in the Hydrodynamic Diffraction analysis only solves the diffraction problem at the corresponding encounter frequencies, it does not apply a forward speed in the time domain. As you suggest, in the time domain the model will be moving backwards due to drift effects.
      3. To run a time domain analysis with forward speed, we usually recommend moving the water under the vessel, rather than moving the vessel through the water. You can do this by the following steps:
        1. Add a constant velocity Current to the Hydrodynamic Response analysis, with a Direction of 180 degrees and Speed equal to your forward speed (i.e. 10 kts, 5.144 m/s).
        2. In the Hydrodynamic Response Analysis Settings, confirm that the option 'Account for Current Phase Shift' is set to 'Yes' (this is the default). In this way the incoming wave phases are adjusted to account for the current speed.
        3. You will need to apply some kind of constraint to the vessel to stop it from drifting away. You could do this by: adding soft mooring lines around the vessel; deactivating the vessel Global X motion (only); applying a user-defined external force function, i.e. modelling a dynamic positioning system to counter the vessel's drift motion.
      I hope this helps!
      Mike
    • Vishnu R.
      Hi Mike,
      Thanks for replying to all my queries. Yes, you are spot on. My GMX is negative. I should have checked this earlier. I think I made the most basic mistake of mixing up the coordinate system. While preparing the geometry in Design Modeller, I had translated the model vertically down so that the waterplane coincides with the X-Y plane. But in Aqwa, I gave the VCG with reference to the baseline of the vessel which would have resulted in the negative GM. So in my case, the VCG should measured from the waterline, isn't it?
      I hope this will solve all the errors. I will also try the method you suggested for simulating forward speed in time domain.
    • Mike Pettit
      Hi Vishnu,
      Great - I'm glad there is an easy explanation for this, I wasn't sure what else to suggest! You are right that the global coordinate system in Aqwa defines Z = 0 at the waterline. So, the VCG position should be relative to the waterline, not the keel.
      Cheers, Mike
    • Vishnu R.
      Hi Mike,
      Could you also explain how to use disc elements to define the viscous roll damping. The vessel which I am analyzing, does not have bilge keel. So, I want to include only the viscous drag component of the total roll damping. Is it something like defining many discs along the hull and give some drag coefficients? How do I transfer the wetted area to these discs? Alternatively, is there a better method to do this?
      Thanks.
    • Mike Pettit
      Hello Vishnu,
      The simplest method for modelling viscous roll damping is to define a Morison Hull Drag Coefficients matrix with a non-zero RX-RX term. This value is multiplied by the square of the roll velocity to give a damping moment that is applied at the structure COG. Naturally you will need to provide an appropriate roll drag coefficient.
      Alternatively, you can define Morison elements on the structure to model the viscous drag. You cannot choose which freedoms the drag forces/moments are calculated for - you will always have 3 forces and 3 moments acting at the structure COG due to the drag calculated on the Morison elements. The Morison elements can be either:
      • axisymmetric tubes, created in the geometry editor and associated with circular cross-sections, for which you define a single added mass/drag coefficient;
      • non-axisymmetric tubes, created in the geometry editor and associated with rectangular or non-uniform cross-sections, for which you define separate added mass/drag coefficients in local x and y directions;
      • discs, created in the Aqwa editor, which are point-like Morison loads with a single added mass/drag coefficient.
      Using this approach the drag force on each Morison element will vary depending on the structure's position (i.e. drag drops to zero when an element leaves the water), but you still need to provide appropriate drag coefficients. Added mass coefficients should be small to avoid double-counting the structure added mass (assuming you also have diffracting panel elements in the model). For more information on this please see the discussion in https://forum.ansys.com/forums/topic/ansys-aqwa-how-to-add-insert-fins-for-damping-at-our-marine-structure/
      I would certainly recommend Morison Hull Drag Coefficients as a much easier approach.
      Cheers, Mike
    • Vishnu R.
      Hi Mike,
      Thanks again.
    • Vishnu R.
      Hi Mike,
      I tried to add some stiffness for the surge and sway motions to prevent the vessel from drifting away in the time domain simulation. I used the option Connection Stiffness. However, after I run the diffraction solver I found that this stiffness was not used. I got the following warning.
      What does this mean? How do I correct this? I checked the thread which discussed about this but, I understand that was about Hydrodynamic Response and not Diffraction. I did not find NASF option in the .DAT file in case of Diffraction. Also, what is the difference between adding Additional Hydrostatic Stiffness in geometry and the Connection Stiffness?
Viewing 7 reply threads
