Error in CFD-Post
    • zama101
      Hello everyone, im suffering some errors while trying open CFD-Post that does not allow me to analyze correctly my model. The two errors I am having are these:
      - File '\AB000FS0118_DataernoDesktop3D3Dsim_filesdp0FFFFluentFFF.1-3-00033.dat.gz' does not exist or is not readable.
      -CCL parser failed with message:
      invalid parameter value "., \AB000FS0118_DataernoDesktop3D3Dsim_filesuser_files": control character number 8 is not allowed.
      Ive checked that FFF.1-3-00033.dat.gz is in the folder and i can open the case perfectly.
      I am not sure if this information will be enough but if anyone has any tip that will help me to solve this issue, i would be very grateful.
      Thanks in advance.
      Check the path, but also, what's the character
      8_DataernoDesk
      represented by the square?  I'd do the post processing in Fluent too, saves moving to another code and pretty much everything you need is there (we've been upgrading the tools in Fluent and stopped teaching CFD Post in the Fluent Intro course last year).
    • DrAmine
      Special symbols or characters are not allowed. And my colleague highlighted to post process in Fluent.
    • zama101
      Thank you very much for your response, I have checked and you are correct there is a especial character, $. This character should not be there but as i am working from a remote pc the folders seem to have all of them that character. I will try it in the physical computer. If is possible to do the post processing as you said in Fluent that will be a relief.
      Thanks for your help.
      Kind regards,
      Borja
      None of the ANSYS tools will like the $ symbol, but may work. Depending on how Fluent sees it you may be OK, but it's something to raise with your IT department. As an aside always try and work locally: saving/reading over a network is a good way to lose data. Copying files doesn't suffer from this as the file transfer codes are designed to account (or fail cleanly) when doing this.
    • mopio
      In addition, the folder for the report  is empty
      Any guide?
Viewing 5 reply threads
