May 16, 2022 at 4:32 am
weij2018
SubscriberHello there! I am doing a conjugate heat transfer project of gas-turbine. After about 600 iterations, the ANSYS CFX solver has terminated without writing a results file, and shows this error in cfx5solve.Please any one give me the solution.
May 16, 2022 at 1:23 pmRK
Ansys EmployeeHello,
I would suggest to start off with a small value of time scale and then gradually increase it.
May 18, 2022 at 12:46 amweij2018
SubscriberThank you, sir. After I changed the Timescale Factor from 1 to 0.5, the problem was solved.
Trending discussions- Floating point exception in Fluent
8740
4658
3151
1678
1452
