June 26, 2019 at 1:06 pm
AS10
SubscriberHello Everybody,
I got this following error in the CFX-Solver: "The ANSYS CFX solver exited with return code 1. No results file has been created." and "Update failed for the Solution component in CFX. The solver failed with non-zero exit code of 2"
Can someone help me, to fix this error? I have got a Workbench Archive file.
Kind Regards
June 26, 2019 at 2:45 pm
DrAmine
Ansys EmployeeANSYS Staff do not download attachments. Please insert the lines here. The error message might be caused by a lot of things. You can off course share whatever you like but ANSYS Stuff would not download these attachments.
Can you describe your case please?
June 26, 2019 at 3:15 pm
AS10
SubscriberThank you for the fast Response. I want to simulate an F1 Frontwing. But now I have the Problem to get the results (solution)--> to run the solver.
I got the error shown: "The solver failed with non-zero exit code of 2"
In the following there are the whole Error and mesh description: I hope that is helpful:
My Systeminformations are: Surface pro 6, Windows x64, Intel Core i7, 16GB RAM
Best regards
June 26, 2019 at 3:55 pm
DrAmine
Ansys EmployeeGo to the partitioner part any messages? CFX is complaining about mapping regions.
Please add screenshot of geometry details domain definition from Pre. -
June 26, 2019 at 5:04 pm
June 26, 2019 at 5:06 pm
June 27, 2019 at 5:01 am
DrAmine
Ansys EmployeeI meant partitioner part in the outfile. Do you see any errors in Pre? Can iyou u check if the fluid domain is consistent? Give the fluid domain a name in meshing.
SAS is a SRS approach it requires CFL smaller than 1 and LES grid whereever you want to resolve the flow. -
June 27, 2019 at 6:32 am
AS10
SubscriberHallo, i will be out of Office until Monday. In that time i don't have Internet, to communicate. I will give you the required informations on Monday. Thanks for your big help.
June 27, 2019 at 8:04 am
DrAmine
Ansys EmployeeWelcome.
3820
2607
1853
1244
600
