February 24, 2022 at 8:37 am
Dinesh_R
SubscriberMaxwell2DDesign1 (Transient, XY)
[warning] Maxwell2d solver, process solver2d: Internal Solver Warning: 'Simplore coupling Or simulink coupling, stop checking steady state '
[warning] [Sim2000App] Warning 10907 - A complete convergence within the maximum number of iterations allowed of <40> could not be achieved for all time steps. Convergence failed on conserved terminal
. Node: net_36<%> >> Calculate at t=0.001 s [Sim2000App] Info - Simulation stopped by user. >> Calculate at t=0.001 s
SDB file "E:Co-simulation of Electric Traction Driveansys maxwell 21.2.aedtresultsSimplorer2 empTR_TR_S0_V337_R0.sdb" saved.
Simulation completed successfully. Time: 4.098000 sec.
Normal completion of simulation on server: Local Machine.
February 24, 2022 at 10:11 amDinesh_R
SubscriberHello i need some help in the cosimulation of ansys and matlab i got the above error, Kindly someone help me to clear the error Kindly please see the attachment.
March 2, 2022 at 11:52 amNavya C
Ansys EmployeeHi @Dinesh_R You may ignore the warnings.
Your data says "Simulation stopped by user"
It also says "simulation completed successfully." What is the error?
It's a bit confusing.
did your simulation complete successfully?
If the model is not converging increase the mesh and number of cycles in the analysis setup.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
