August 15, 2023 at 8:11 am
Aadya Goel
SubscriberHi, I'm following this video:
&ab_channel=AnsysHowTo to prepare the geometry for CFD, but at 1:46 when the enclosure is being created, I'm getting this error: An error occurred while creating the enclosure - 37 bodies could not be subtracted from the enclosure body. The file I imported has both surface and solid components. I'd really appreciate any help. -
August 22, 2023 at 3:27 pm
Luca B.
Ansys EmployeeThis error reports that you cannot complete the enclosure due to some problems to your geometry that does not permit to complete the boolean operation ( subtraction ) .
The Suface components cannot be used to create an enclosure, only solid parts are considered.
In your case if Enclosure fails it could be dependen on defects on you solid body. Verify that it is a solid without defects ( check with repair tools ). You can also try bolean operation manually, with Combine tool. You can apply it to smaller portion of your geometry in order to identify the corrupted parts and correct only it.
Luca
- Limitations of ANSYS Student
- When DesignModeler is a better choice than SpaceClaim
- Off setting lines onto surfaces
- Rosette direction issue due to Geometry limits
- Applying Moments for the Revolute Joints in Explicit Dynamics
- Free ANSYS Research software for Student Competition Teams
- Meshing Problem in Explicit Dynamic-Roll Cage
- workbench
- Ansys Composite prepost analysis
- Analysis of composite parts in student competition
7592
4440
2953
1427
1322
