November 23, 2019 at 11:21 am
Snkaranarayanan
Hello everyone,
I am a master student working in the structural analysis. The aim of my simulation is to find the stress at which the bonded contact breaks. I am using the CZM Model, separation based contact debonding. I had the experimental data for the peel off test and i have calculated the CZM material parameters and after applying, am getting the error, solver pivot error due to inappropirate material properties. I do not know how to proceed from here on and am looking for some suggestion. I have attached my stress-strain graph along with the material properties.
Also am working in the 2D model and am using the axis symmetric along y axis and in the contacts am using the bonded, Augumented lagrange. Normal contact siffness factor as the 0,2.
November 25, 2019 at 3:52 am
sk_cheah
SubscriberA quick google search of: czm ansys
should give you some good resources.
Best,
Jason
3355
2471
1310
1018
