June 9, 2022 at 9:15 am
guessoum.anis
SubscriberHello
I am trying to set a demagnetiztion computation for the magnets in a motor after I apply a heavy load current. I followed the instructions from the help guide, so I set identical source and target designs.
When I try to run the target design, i get this error : Maxwell2d solver, process solver2d error: Internal Solver Error: ' Map source design 'solvedhc' file onto target mesh failed! '.
Im using Ansys EDT 2021R2, the geometries in the source & target designs are strictly identical. The magnets and steel sheets im using have non linear BH curves.
I will be grateful for any help you could provide.
Anis
July 25, 2022 at 7:40 am
Navya C
Ansys EmployeeHi @guessoum.anis,
Can you provide more detail, preferably screenshots of which instruction manual are you following?
Navya
August 2, 2022 at 11:58 am
guessoum.anis
SubscriberHello,
Here are some screenshots of wich instruction manual im following :Im doing this analysis on the following motor :
I followed the previous instructions and i would like to import in the target design the magnetization state of the blue magnet after i run a computation in the source design with a heavy current in the stator. I get the error aforementionned when Im doing this.
Please tell me if this is not clear enough.
Thanks a lot.
Anis -
August 5, 2022 at 1:02 pm
HDLI
Ansys EmployeeHello,
Please review the knowledge materials (KM) in https://support.ansys.com/KnowledgeResources/Solutions?solutionIdentifier=sol2042685&productName=ANSYS+Maxwell&productFamily=Electronics
If having Ansys learning hub access, please go to https://jam8.sapjam.com/groups/NA4AXmq6h4aU43Ap36G0uU/content?folder_id=TT5bLYQWQ3Ri6dtPW5h3m9
HDLI
March 29, 2023 at 5:17 pm
Hesham Saeed
SubscriberHello Anis,
Have you solved your problem? I did have the same issue you mentioned above.
I'd appreciate your help.
- Maxwell, HFSS or Q3D?
- Error
3862
2635
1859
1254
600
