June 24, 2022 at 11:30 am
sandeepn20
SubscriberHello Everyone!!
I am working on an eddy current braking system. The objective is to match the analytical results with the simulated one. But, the results are not good. I encountered that, the eddy current is shifted by some angle from the pole shoe. I don't understand this effect. Please help me to identify the issue.
Thank you..
July 5, 2022 at 10:59 am
Navya C
Ansys EmployeeHi @sandeepn20,
Can you provide the below details?
> Geometry screenshot in other direction.
> Does this include any motion setup? and screenshot of setup
> Can you share the B field plot.
Navya
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
