Error in element formulation
    • masud407
      I was trying to draw stress strain curve for the attached structure by using ABS materials. My design consists of some unit cells. Therefore, I have to use command object for each part to simulate the properties of the materials which is given in the following link:
      https://drive.google.com/file/d/0Bz1z-D9h96HYeWwwT01GLWlZRW8/view
      I have applied force at one end of the structure and a fixed support from other end. However, It shows "Error in element formulation" in the solver type.  Note that, I have used hexa dominant method meshing with fine sizing. Solver output result is provided in the following link:
      https://drive.google.com/drive/folders/1j_1wrKNSe8FH_gdf4F1mNjBac4RgWxRA?usp=sharing
      So how cal I resolve this issue? Any suggestion? Thanks in advance.
    • peteroznewman
      The second google drive link lacks permission to access that file.
      If you assign an isotropic elasticity material to this structure, does it give the same error?
      For further assistance, it would be best if you Attach a Workbench Project Archive .wbpz file to your reply.
    • masud407
      I haven't assign isotropic elasticity material yet. How can I do that? I have changed the material properties according to ABS properties.
      Can I have your email ID so that I can send the solver output to you? I have also provided the shareable google drive link in my post as well.
    • masud407
      Mr. Peteroznewman,
      Actually, I am using ANSYS from a server with the help of a software named as Citrix. Therefore, I could not extract the .wbpz file according to your provided link.
    • peteroznewman
      Did you try creating a Workbench Project Archive?  How big was the .wbpz file?   If you right click on Mesh or Model and Clear Generated Data, then Save As and then File, Archive, you will get a nice small file.
      Do you see the Attach button on the right of your post above?  You can use that to attach the .wbpz file to your post, then I can get it from there, mesh and solve and I will have everything you have.  email is used when all else fails.
    • peteroznewman
      I know Citrix is software for remotely operating software on a server.  There is still the Workbench File, Archive menu item, it will just write the file on the server instead of locally, the same as your Workbench project files.  You can get to the files saved on the server, right?  Just attach the .wbpz file to your post above.
    • masud407
      I tried to archive the file and save it in wbpz format. However, I could not managed to do it by using citrix. Is there any other way to show you my working file?
    • peteroznewman
      If your ANSYS files are in a folder called userwork and your project is called cube, then there will be a file called cube.wbpj and a folder called cube_files.
      If you go up to the user folder and create a zip file of the work folder, then you will have both the cube.wbpj file and cube_files folder inside a zip file.
      Attach that zip file to your reply if the file size is < 120 MB.  If it is too large, reply with a link to the zip file on your Google drive.
Viewing 7 reply threads
