Discovery Import
Discovery Import
Error in export to dxf
    • rg
      Hi
      I have a client that sometimes exporting to dxf an explained one exports it incorrectly, during the export (even if hidden) exports the lines of fold ( I attach video and files).
      During export creates a layer called HIDDEN
      What’s the cause? Use version 2020R1
      Best Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Hello Robert ,
      I will look into it and get back to you.
      Charudatta
      Hello Robert ,
      I imported the .scdoc files you have shared and exported the dwg file in 2020R1, and I faced the same problem.
      I tried recreating the geometry with the same dimensions, bend allowance and bend deduction (find attached), and exported this file to .dwg/.dxf, and did not see the bend lines. Can you please verify them at your end, by then I will investigate the issue in the original file.
      The hidden level does get created in .dwg, but I have not seen any lines there, will look into it too, and understand the reason behind it and will get back to you.
      Regards.
    • rg
      Hello Charudatta Bandgar
      Hi, I also tried your file and it has no problem, the dotted line is not present
      Best Regards
        Hello Robert ,
        Thanks for the confirmation. I will get in touch with the experts and figure whether this is problem specific or is repeated behavior/bug.
        Charudatta
    • rg
      Charudatta Bandgar Hello
      Thank you
        Hello Robert ,
        Sorry for the delayed response.
        I have filed a bug report (Bug ID: 315053) (although it seems to be a model-specific issue), and I am awaiting a response from the developers. I will update you about it, as soon as I get any information.
        Regards.
      • rg
        Charudatta Bandgar Okay thanks, it's not a problem if you answer me now
        Regards
Viewing 4 reply threads
