March 16, 2022 at 7:35 am
ztjia
SubscriberAfter calculating more than 2000 iteration steps on average(enable Data sample for statistic), the problem of not being able to calculate appears, and the detailed page is shown below, and there is no response when clicking on the Fluent page.
"0: mpt_accept: error: accept failed: No error
The fl process could not be started.
Error: Error writing "C:/JZT/temp/(12)-wu-sm-new turbulenc model/244Ratio5/03-SBES-SM/244-Ratio5-SBES-SM-1-16.460253.cas".
Error Object: #f"
March 16, 2022 at 11:21 amRob
Ansys Employeempt tends to be a parallel problem, but check the TUI to see what's triggered it. The error looks to be as the file was written. Has the solver written to that folder before? Adding brackets into paths often causes problems, and most Ansys staff also avoid spaces as we work on a mix of Win10 and Linux.
March 21, 2022 at 1:36 pmztjia
Subscriberthanks for your reply,I will try it.
2524
2066
1285
1096
459
