October 11, 2023 at 12:13 pm
October 12, 2023 at 1:15 pm
Gary Stofan
Ansys EmployeeThis is a brief procedure assuming you have a .mechdb that is intact.
Sometimes re-importing the mechdb/mechdat can resolve these issues.
In your project folder, there should be a SYS.mechdb file for each Analysis object that was on the schematic.
- Make a copy of SYS.mechdb to another folder,
- Rename the copy to SYS.mechdat
Once you have copied these out, create a new Project..
From Windows Explorer, drag the .mechdat files into the Schematic
Save the project to a new name when you are done.
Let me know if this gets you going.
October 12, 2023 at 1:22 pm
Ashish Khemka
Forum ModeratorHi,
Try the following:
Make sure no Ansys programs are running
Go to :
%APPDATA%\
(This should take you to a directory: C:\Users\\AppData\Roaming\)
You should see a directory named: Ansys
rename that directory to: Ansys.old
Now try to run.Regards,
Ashish Kumar
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Results Probe in ANSYS Workbench
- Unable to delete system in Ansys Workbench
8808
4658
3151
1680
1470
