error in interpret udf in parallel Fluent (Linux x64)
    • mysm
      We use Fluent 17.2 in our University.
      I have a udf file that interpret works fine in university's windows cluster in parallel mode.
      but in Linux(CentOS 7) base it shows error like this:
      error at node 004: error: udf compiler: unable to open udfconfig-node.... for write.
      error at node 123: error: udf compiler: unable to open udfconfig-node.... for write.
      error at node 056: error: udf compiler: unable to open udfconfig-node.... for write.
      What is the problem?
      all my files are in a shared working directory with read/write/execute permission to all.
      In Serial mode it works properly!
    • DrAmine
      1/Centos was not supported for R17.2: So do not expect that it has to work or tht someone might help you there.
      2/I would first try to copy only the case and the UDF file and try to interpret (not other files) to check if it is a configuration issue
      3/Why not compling on Linux?
