error in journal file (on HPC)
    • mohamad
      I'm trying to use journal file for HPC but i have an error.
      what can i do for fix it?
      journal file:
      parallel/partition/auto/use-case-file-method yes
      file/read-case case144.cas
      define/user-defined/interpreted-functions "case14.c" "cpp" 10000 no
      parallel/partition/print
      solve/report-definitions add report12 volume-average field liquid-fraction zone-names (pcm) quit
      solve/report-files add liquidfile frequency 1 report-defs (liquid-file) quit
      solve/report-plots add liquid-plot report-defs (liquid-plot) quit
      solve/initialize/initialize-flow
      file/auto-save/data-frequency flow-time 1
      file/auto-save/append-file-name-with flow-time 1
      solve/set/time-step 1e-1
      solve/dual-time-iterate 10 30
      solve/reporting-interval 30
      file/confirm-overwrite no
      file/write-data case144.dat.gz
      exit yes
      Error:
      > solve/report-files add liquidfile frequency 1 report-defs (liquid-file)Invalid report definition  quit
      Report Definitions(1) [()] solve/report-plots Invalid report definition
      add Invalid report definition
      liquid-plot Invalid report definition
      report-defs Invalid report definition
      (liquid-plot)Invalid report definition
       quit
      will be very appreciated by your help. Thank you in advance.
    • DrAmine
      Line by line you need to debug where it starts getting the issue. It seems related to the report definition and file. Probably using the wrong report definition name.
      Always start the command line with / too ie
      /file/read-case case144.cas
      otherwise you are relying on the commands to return to the root level every time.
      What is the "quit" command for? To terminate a list use () ie open & closed brackets with no space between them.
