Ansys Products
Ansys Products
Error in licensing
    • krishnatejavaleti
         I recently downloaded  ANSYS team software (structure and fluids package) and installed as guided.But i'm facing trouble during licensing.
         After installation of license manager,it showed a message to check the error file generated during licensing,I attached the  some pics  regarding the     troubles I faced and the screen shot of the error file.
              Please ,help me regarding this.
               Thank you.
    • tsiriaks
      Hi krishnatejavaleti,
      Unless you received ANSYS license file from your ANSYS Account team, you will have to specify the license server in your school (not your own machine). Launch that tool with 'run as administrator' to change license server specification.
      Thanks,
      Win
    • krishnatejavaleti
      Hi Win,
         Thank you for your guidance. I recieved ansys license from ansys team account and I specified the license server on my machine and changed the server              specification as described above.
         But ,still ,when I open the workbench I can not able to see the complete tool box,only a few icons are available.
         Regarding the package,I installed structures and fluids complete package and granta selector.
      Please help me regarding this.
      Thank you.
    • tsiriaks
      Check your Windows environment variables to see if you have ANSYSLI_ELASTIC or ANSYSLI_LCP set. If so, remove them.
      Also, try the following command in CMD Prompt
      move "%appdata%ansys" "%appdata%ansys.old"
      If issue persists, post the output of the
      set
      command from CMD Prompt
Viewing 3 reply threads
