September 30, 2018 at 8:06 pm
mqasim
SubscriberHi, I'm simulating an induction motor in 3D. I have an outer rotor and inner stator, and the band is encompassing the rotor up to the middle of the airgap. When I set the mechanical speed in motion setup to a speed that is greater than zero, I get the following error: 'Error in mesh mapping on band error' I was wondering how to fix this problem. Another question, which is more accurate in torque calculations: Moving1.Torque or the user-assigned torque parameter on the band (Torque1.Torque)? Thanks, Mohamad
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
