September 30, 2018 at 8:06 pm
mqasim
SubscriberHi, I'm simulating an induction motor in 3D. I have an outer rotor and inner stator, and the band is encompassing the rotor up to the middle of the airgap. When I set the mechanical speed in motion setup to a speed that is greater than zero, I get the following error:
'Error in mesh mapping on band error'
I was wondering how to fix this problem.
Another question, which is more accurate in torque calculations: Moving1.Torque or the user-assigned torque parameter on the band (Torque1.Torque)?
Thanks,
Mohamad
Viewing 0 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2630
2104
1327
1110
461
Top Rated Tags
