Error in Meshing for fluid flow analysis
    • ak_thawait
      Hi, I am meshing two spherical body with multizone meshing. Meshing is completed but I am getting bad quality elements near the discontinuity and because of this, not able to transfer mesh in Fluent. How can I improve mesh quality?
      Thanks.
    • Karthik R
      Administrator
      Hello,nI'd strongly recommend to modify the geometry slightly to avoid a point at the trailing edge. Instead, please change this to a small edge at the trailing edge. This should not affect your overall simulation results and will help you obtain a much better mesh. nI hope this helps.nThanks.nKarthikn
    • ak_thawait
      Thank you very much Karthik..n
