March 19, 2021 at 12:46 pm
Bobby11
SubscriberWhy motor torque is falling by ~3Nm by simulating only one pole of motor compared to full motor?
I have also appropriately given boundary condition. Please help.
March 19, 2021 at 3:05 pmNavya C
Ansys EmployeeHi @Bobby11,nCan you check if you have exactly the same Analysis setup for both conditions?nRegards,nNavyan
March 20, 2021 at 6:11 amBobby11
Subscriberyes ..i have same settings. nMarch 22, 2021 at 4:51 pmHoward
Ansys EmployeeHello Bobby11,n It is an interesting question and we may check everything in both model. Here is some information. nGeometry. Could you check the if the one pole geometry can present the full geometry? In the one pole model, do you use Master/Slave or Independent/Dependent, and Bs = - Bm , Bdep = -BinpnMaterial. Please use the same materials and magnet directionnMeshing. Please use the same meshing and improve the meshing to achieve the accurate results.nCheck the length and skew option in Design setting.nCheck the excitation and Setup's setting.n The results should be same if the one pole model can present the full geometry. Thanks.nnViewing 3 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
