March 21, 2022 at 8:21 pm
pvp1
SubscriberHi,
I've been trying to recreate a simulation created in another software. They previously reported the Mu and D1 but the shear stress curve that was generated was different. Is there a setting I can change so they're matched? The image below is my output from ANSYS
March 22, 2022 at 2:31 pmJohn Doyle
Ansys EmployeeThe shear response should always fall between the uniaxial tension and the biaxial (compression), with biaxial being the steepest curve and uniaxial being on the bottom. I am not familar with WISIM, but the shear and tension plots look out of order. Maybe it is just a labeling issue.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
